Seems like it would be unsafe.
IF you use longer, grade 8 bolts, and IF the cables and lines are long enough, and IF you can deal with the issues of things hitting the fairing corners, it should be fine. Like any other mod, if done correctly, safety is not a problem. I know several people who have double-stacked Genmar risers on their ZZR 1200s and those are 1 1/4" each, so doubling the 3/4" Helis should pose no safety issue if you use the proper fasteners.
