Pulling my hair out with this. Hoping somebody can help.
Had my new race engine running nice in my road bike to make it easy to test on the road. Transferred it over to my race bike and noticed the Gray wire is showing 12v. So somehow there is a short in the ignition switch. Not problem I thought because I am nearly finished building my race loom which does away with the key.
I have a whole bunch of 100 ohm resistors to take the voltage down to 6v for the gray wire. As a really simple test I have unplugged the ignition switch and just looped a wire with spade connectors between the white and brown and then jumped from the brown to the gray wire with a 100 ohm resistor. When I test with a multimeter I still get 12v.
Just to make sure nothing got in the way of testing that the resistor worked I put the multimeter negative to the negative battery, the multimeter positive to the end of a resistor held in one hand, the other end of the resistor to the positive of the battery and I still get 12v. I can only assume my logic of how this needs to be wired is incorrect?
Any help would be appreciated as I need to get this running by the weekend. I can see myself buying a 6v battery at this rate to get it started!
