Hello Everyone,
I'm looking to do a simple up grade to my 2000 zx-11. I'm planning on performing the carb needle shim upgrade as well as the K&N air filter. I've already turned my idle mixture screws 2.5 turns out. Should I turn them out 3 turns once I do this? Also, will this even help with the original exhaust system on the bike. I'm also trying straighten out some type of surge with the bike. In 1st gear when giving it the throttle the bike will all of a sudden pick up speed. It's almost as it you let up on the throttle then open it almost wide open. The cable has been lubed and in good condition with no binding.
Discussion Starter · #2 ·
FYI, after checking around I found that Advance Auto has the best price on the air filter for my bike. The K&N filter KA-1093 goes dor $45.99 there...beats all I've seen so far...
