Just picked up a zx7r just clicks disconnected fuel pump relay it will turn over so I bought a new one and still same issue
There are a few simple things to check first. Are all grounds clean and secure? The engine kill switch clean at the contacts? Have you checked the clutch switch at left bar? Side stand switch? Check and verify these simple things first.
Possibly a junction box issue?,give it a tap and see if that works .
I'm having similar issue at moment
I have the same problem with a P model. Same fix by removing the fuel relay. New pump no difference. Fresh battery. Intermittent issue. Has to be connection related, either the starter button, or a voltage drop somewhere I have not tracked down.
