Ok so I ran a car tire for 20,000 miles. Didn't die, worked fine. Now I'm back on my Pilot road. Since the beginning this bike (unmodified) has averaged 43 mpg. Best ever 50mpg, worst 38 running hard.
2 weeks ago, changed rear tire, added new iridium plugs, cleaned air cleaner, replaced water pump O-ring.
Since then my mpg has severely dropped to 36mpg driving my normal droning commute. Tore it down and checked for leaks, nothing. Checked valve clearances -ok, carbs, nothing out of place. The only difference, other then tire and plugs, is the rubber plug on the airbox dropped out and I can't find it.
Will running it with the airbox not completely sealed cause this drop in mpg? I can't find anything else that may be causing this.
Oh, bike is almost at 50,000 miles now.
