make sure you get a set without balancer pipes... the offsets are different but the outlet and design are very similar.
you could also try exhaust form a 9R B1 or B2 code... it drops a bit lower than the 7R header but will fit.
Hey guys quick question. Been searching but can't find an answer.
Will a pipe for a 96+ zx7r fit on a 94zxr750?
Cheers
you need to make sure the later pipes do not have the flanges welded ! the later model zx7 exhaust flanges were turned offcenter and welded .the flange bolt holes do not line up with the earlier l models exhaust studs..talking stock zx7 96+ headers..
