I just installed a full exhaust system and it's leaking at the manifold, any ideas or suggestions?
Are the studs screwed all the way in?
service manual does not call for a specific torque spec, so basic torque table applies. Required Torque depends on the side of the exhaust stud
Standard Torque by Threads Diameter per the service manual
5mm 30-43 in lbs
6mm 52-69 in lbs
8mm 10-13.5 ft lbs
10mm 19-25 ft lbs
12mm 33-45 ft lbs
14mm 54-72 ft lbs
16mm 83-115 ft lbs
18mm 125-165 ft lbs
20mm 165-240 ft lbs
