New to this forum. Bought bike off Craigslist for $500. Very clean 22k miles, new rubber, brakes, K&N air filter. Whole bike is there, all plastics good. Bikes oil level was super high, I think its gas mixed in motor oil. Bike will start but either fouls out plugs or last event gas came running out all over the top of the front fender (never seen this before). I'm assuming carb problems maybe in float area.
Will this bike run with the air box off? Does this air switch on top of the valve cover need to work with vacuum through the air box with these CVK kein carbs?
Took carbs apart this is what I found corrosion in the slide needles. I cleaned them up with 600 sandpaper and muthers alum polish. They came out good. I found two small washer on top of the slide needle clip. They are not there one a parts diagram (why didn't someone just move the clips).
The float valves are in bad shape one is scored up towards the rubber tip. And the other three look like the tips are groove worn.
These float valves are $25 each. Any cheap leads are appreciated! While taking the slow jet out of one of the carbs I found the small rubber oring with a knick in it.
Last, bike compression ranges from cyl one 72 across as high as 85. Could the low compression be from a needed valve adjustment or from the gas mixed in the oil?
