I saw a 93 M model here in the Bay Area today. It is mostly there and in kinda decent condition. The upper is clean, both lowers have some rash and a couple small cracks. The tail was swapped with a ZX7 (two seat) tail and subframe. I did personally confirm it is a M model and has the aluminum tank, FCRs, close ratio transmission. The rear shock was swapped for a fox and it has a Muzzy pipe with a decent aluminum can. The forks are also L model. I do have a correct M model rear subframe, rear shock, front forks, exhaust hangar, and an aftermarket solo tail in primer that I could sell to get it closer to complete (I would need to swap the forks and shock if you want R model stuff because I have them on a stock, ugly L model I am trying to sell). Someone also spliced in an R6 killswitch and throttle. The alloy tank does have a couple small dents.
It is a nice 50 footer. He is asking $3K which seems fair if you are looking for an R model to fix up.
