I have a 92 zx7r with no spark :banghead my parts dealer said the igniter box's do not go out often:headscratch is there a way to test it or maybe the coils? i am going :crazyloco over this, can some one help ?
thanx david
hey man the service manual has these spec's for the coils:primary(little wire terminal) ohm reading of 2.3-3.5 with meter set at R x 1., and the secondary(plug wire terminals) should read 12.000-18.000 with the meter set at R x 1,000. Now take these reading across the two terminals which are alike, so plug wire hole to plug wire hole, and little wire to little wire etc...hope it helps. Also check all fuses and connections..
