Hey guys, I have a buddy that's restoring a '92 ZX7R. He found a wire harness on E-bay for an 89. Will the 89 harness fit the 92? If not what harnesses are compatible with the 92? I have a 96 P model so I have no clue.
Thanks in advance,
D-Patt
Sent from my DROID X2 using Motorcycle.com Free App
Thanks in advance,
D-Patt
If it's a real 92 ZX7R (K model) then ONLY 91-92 ZX7R (K Model) wire harnesses will interchange. You can modify any 91-95 harness to work but you will need the igniter box connector for the K model to splice into the wire harness. You'd also need the wire diagrams for the K bike and whichever bike the harness is coming from. If you're using a Dyna 200 ignition then it becaomes simpler but still requires someone with auto wiring experience.It won't be a simple plug and play affair.
Thanks!
