:headscratch hello all, can any one tell me if a can take the " silencer" out of the front of my airbox and run the bike like that. i notice that is has a oiled foam wrapped around it but its wide open in the center and is befor the real filter. it seems restrictive. my other question is can i put individual filters on each carb. if so what do i do with the rubber hose that goes in the top of the original air box. its at the top and is after the filter and goes to the top of the engine. thank you :headscratch
The prefilter thingie can be removed. Whether it makes a difference who knows.
If you remove the airbox you'll have to install a breather on crankcase vent. The hose leading to the top of the airbox can be plugged. I wouldn't remove the airbox unless you're motor is highly modded. The stock airbox flows more than enough air to the carbs as is.
