I've got a tech question for any body. My 2005 636 has 17k miles on it and the timing chain is making that horrific slapping sound at around 4k to 6k rpm. My local dealer has no tech bulletins on this. I've had the timing chain tensioner replaced twice, each time the noise goes away then returns later. help!
sound like its the chain at fault ...... stretched maybe....... just a stab in the dark.
Could be the chain. Might be a good idea to get a manual cam chain tensioner. You'd have to make sure you remember to adjust it but it may solve some of your problems.
If you put the manual cam chain tensioner on, just measure the chain stretch while you have the valve cover off. There is a spec for it in the book for my 04 so I would think the 05 book would have it also.
did you by chance have the valves adjusted at 15k miles?
