:bangheadmy 2004 ZX6 636, has begun idling way too high. It idles around 3,500-3,800 RPM just sitting in the parking lot, right after starting it up. The choke is off and the idle adjustment is all the way down. I messed around with them 100 times. It started doing this last summer after it was overheating so I replaced the thermostat. Since then it idles like crazy...What else could be wrong with it?? Someone asked if the oil pump is going bad..that wouldnt have anything to do with it, right?
Thanx in advance Everyone!!!!
Are your throttle cables routed correctly?
