:banghead I am going crazy with this electric problem. I think i finally figured out that it is the headlight. WHen i plug in the headlight it starts to mess everything up. Does anyone have a wiring diagram or an idea on how i can check out the headlight for shorts and stuff. Thanks in advance!
If its a short is probably on the harness running to the headlamp, the insulation has probably been rubbed away by friction against something. If you have a multimeter I would disconnect the battery, take the bulb out and test resistance between the positive feeds to the bulb and earth (have the black probe on either the frame or the negative battery lead and insert the red probe into the bulb holder).
Ideally you should be looking for a high resistance, if you get a low resistance its indicative of a problem (unless your looking at the ground wire).
Hope that makes some sense to you, I should have the wirinig diagrams for "e" models but dont know if they differ to yours.
