Good to know. Damn, those 55w beotches put out 5000 LUMENS!!!!Considering that wattage is actually a measurement of heat output (light output is lumens) and standard headlight wattage is 55/60 anyway, there should be no problem so long as your electrical connections are correct and tight.
DW
I would like to see some verification on that, but it makes sense "kind of". An HID outputting the same amount of light will use 50% less power, and run WAY cooler than a halogen light. However, an HID running at the same wattage (electrical wattage, not heat) would put out A TON more light, and have comparable heat.Considering that wattage is actually a measurement of heat output (light output is lumens) and standard headlight wattage is 55/60 anyway, there should be no problem so long as your electrical connections are correct and tight.
DW
Watts is a measurement of energy as Masta states (most commonly used in electricity, but could be any type of energy) so a 55 Watt standard bulb uses (dissipates) the same total energy as a 55 Watt HID light. The sum of all that energy is put out as heat and light. It makes some sense that the HID light will put out less heat if it putting out more light. Just as a comparison, a liter class bike engine puts out roughly 100,000 Watts.I would like to see some verification on that, but it makes sense "kind of". An HID outputting the same amount of light will use 50% less power, and run WAY cooler than a halogen light. However, an HID running at the same wattage (electrical wattage, not heat) would put out A TON more light, and have comparable heat.
So, AFAIK it is in fact an electrical measurement, but 55W cant possibly create more heat AND light than a halogen. One or the other, sure.
Either way, I have never heard of anyone actually melting a headlight housing with a 55w HID kit that wasnt already melting it with a stock bulb.
Only if its a 55w halogen too.I'll shoot my buddies bike that has 55w with a temp gun and shoot one from halogen light. That will settle the heat discussion right?
Can't read?Dont know why there is a debate going on.
