Did you buy the bike new from a dealership? If so, take it back to them with your concerns. If it's a faulty caliper or master cylinder, they should be able to replace it at little to no cost to you.
Did you buy the bike new from a dealership? If so, take it back to them with your concerns. If it's a faulty caliper or master cylinder, they should be able to replace it at little to no cost to you.My bike only had 20 miles on it when I was doing a brake test. I coasted around a corner in first, when the bike straitened up I got in to the throttle hard, shifted to second and stayed on the throttle, shifted to third then pulled in the clutch and started applying the front brake. As soon as my foot touched the rear brake pedal the rear brake locked up and would not release. I even tried pulling up on the pedal with my foot with no change. Before hitting a car I had to grab the front brake hard causing the rear tire to leave the ground. As soon as the rear tire made contact with the ground, the engine started to chug hard about 10 times and then died. I had the clutch pulled in the whole time. I started the bike and tried to get it to repeat what happened at lower speeds but could not get it to repeat it. My concern is it'll happen again at high speeds. What should I do? View attachment 23914
Yes, it only had 1 mile on it when I purchased it. They came to my house and trailered it to the dealership and hooked it up to the computer. They said it doesn't have any codes and everything seems to be working fine. The rear brake reservoir is plumb filled to the top with no air visible between the top line and the lid. They said that's ok, but I've never known it being ok to completely fill a reservoir. View attachment 23924
Do what @TaxmanHog suggested. I can't believe they would only hook it up to the computer for diagnostic and not look at it from a mechanical POV. I'm disappointed.There should be a bit of air gap in reservoir, though the cover/seal has an expansion bladder that might make it seem to be full, pull the cover off and view the level.
Could there be a collapsed hose locking up pressure and caliper?
All issues are odd for a brand new bike.
Keep us postedI still have to pull the cap for the reservoir. I also have an appointment with my tuner. He'll give it the once over. He's not very happy with it either.
