Hi all, newbie here, not my first ZX6 but my most recent, and setting it up for some track time.
I just picked up a full front brake set from a ‘13 ZX6R and planned to fit this to my ‘06 for some improved braking, and because I like a project, who doesn’t!
I mounted the rotors/discs no issues, and in offering up the caliper to the fork mount I can see that I need to shave 4/5mm from either the fork mount, or the caliper itself to obtain full pad to disc contact. No issues there, I have a local machine shop. I would machine the calipers rather than the forks to allow me to return standard ’if’ required.
My real query is, I can see the ‘13 plus has a dowel arrangement on the fork to ensure the caliper is mounted perfectly square to the fork leg/rotor/disc. My thinking is, that once all mounted up, bled and still loose, I can apply brake pressure which will pull the calipers square to the disc/rotor, then torque the bolts accordingly which will ensure everything stays in place. The forces on the caliper through braking will not be of a side to side nature, only radial/circumferential, therefore I am fairly sure there should be no issue with my plan! I was also considering, if nobody has experience, having the machine shop fabricate some studs with a machined collar to locate the caliper on. So screw the stud in tight to the leg, then mount the caliper on the protruding stud and fix with a licking nut??? Or, I can see that there’s a closer tolerance and tighter fit with the mounting bolts with the tokiko calipers. I could have the machine shop just make me new mounting bolts, with a similar .03mm clearance on the bolt shank, which would hold everything as central as the old calipers were.
Has anyone carried out this modification? I’m hoping for some real world experience, otherwise I may consider selling the calipers I have in favour of some from an ‘07/08 bike, however that means me dropping back to the 300mm discs rather than the 310mm I picked up with the ‘13 set up.
I paid next to nothing for this set up, and the machining wouldn’t cost me a thing, so kind of keen to make this work. 👍🏻
