1 - 8 of 8 Posts
I finally got it running and now when it cranks it shuts off after about 10 seconds and wont crank until i turn the key off and on then it does the same thing
Discussion Starter #3
Nada i took the injectors off and cleaning them out and checking my wiring cause it was working till the rain
Double check all your hoses under and beside the airbox. If I recall this happened to me and it was because one of the hoses slipped off.
Sounds like the synch ports may be unplugged on one or more carb. That's where I would start my search. It could even be a dryrotted hose.
Having the same issue with my 07 as well. It's like it only runs off what's initially pushed into the system when the fuel pump kicks on. Starts, idles, & revs great for a whole 5 or 6 seconds until it burns off that first blast of fuel . 1a
1 - 8 of 8 Posts
