I bought a new 2007 ZX-10R a month ago and have 950 miles on it. Afetr the first 600 were gone, I started to get on it a little more. I found one problem and was wondering if anyone else has noticed the same. If you have the bike in 2nd gear and get it up to about 7,000-7,500 rpms, and then let off the gas and let the rms go down to about 4,500-5,000 and then hammer down all the way on the throttle, it will stall out and not go anywhere until you let off the gas and try it again. This happens about half of the times you try it. However, if you slowly roll the throttle all the way, it does not have that problem. I found this out racing my brother on his 07'
R1 in a 2nd gear roll on at like 50-55 which is in this rpm range. This is the only gear it will do it in and there are no other problems with this bike I love it. Should I have it checked or amount it to something else. Also, who else has this problem. Try it and let me know.
Thanks,
Mike
Newby
2007 ZX-10R RED!!!!!!
Sounds weird, take it to the shop. I have the same bike and it never does that.
