1 - 20 of 31 Posts
2006 frame with clean title (perfectly straight) $1200
Motor kit w/ just over 7kmiles $1300
subframe $50
wheels with rotors $400
Rear suspension conversion (swingarm, linkage, rearcaliper/line/hangar, shock, axle) $150
front driver seat $20
rear solo seat cap $60 (blue)
left and right rear sets $40 for left and $60 for right)
tank with cover $100 (matte black but was painted professionally)
Tank $125 Blue
Forks with upper and lower tripple $200 (good seals)
gauges with 12k miles $100
clip ons $40
front brake calipers w/ new pads $40
Front master cylinder $50 (includes resi, lever and master)
ram air tube $80
upper fairing stay $30
left lower fairings $50
right lower fairing $70
Mid fairings $50 each (matte black)
headlight w good tabs $150
CHain w/ 600 miles $30
lock set (includes gas cap, ignition, trunk lock) $100
trim plastic under seat $20 each side.
dash trim pieces $25 each or $40 for both.
stock mid pipe $20
stock exhaust $30
passenger rearsets $30
front fender $50 Matte black, and i have a magma red one
tail light $30
stock grips $10
hand controls/switches $15 each side
stock bar ends $15
undertray/trunk plastics $15
plastic panel under headlight $15
fuel pump $40
all OEM fairing bolts from bike $30 (over 30 of them)
throttle asym (cables, tube, housing) $30
rear OEM blinkers $20 for both
ECU $150
wire harness $100
stock header $20
VP Whoring
Condition of right side dash trim?
I need an 06 ecu for my 05 636 but they normally go for a lot less, around 80 I'm fold. If you're not firm on price can you text me and we can work something out? Sorry to be cheap, it's been an expensive summer :-/. My number is 8143231917.
Thanks man
-dan
Discussion Starter · #10 ·
i have an ecu but ive never seen one go for $80. If it did then it probably didnt work or the guy just had it lying around. Going price is $150 and i keep mine at that. Go to ebay and you will really see an inflated price of them.
VP Whoring
Have you got a mint right side dash trim?
front weel pm me
You do 50 shipped on right rearset? Get at me asap.
Sent from my SAMSUNG-SGH-I897 using Motorcycle.com Free App
1 - 20 of 31 Posts
