My Settings
Old Son, Had My Suspension Tuned, Heres My Settings.
I'm 165 Pounds, So Your Set Up Will Be Different, But Maybe This Will Help.
Initial Settings Final Settings
Front Preload: 7 Lines Preload: 4 Lines
Comp: 10 Clicks Out Comp: 4 Clicks Out
Re: 9 Clicks Out Reb: 2 Clicks Out
Sag: 36mm Sag: 32mm
Rear Preload: 20mm Preload: 23mm
Comp: 3.75 Turns Out Comp: 1.5 Turns Out
Reb: 2.75 Turns Out Reb: 1.5 Turns Out
Sag: 33.5mm Sag: 32.5mm
According To My Tuner, My Suspension Was Set Pretty Soft.
Comparing To The Mag Article, It Is Somewhere In Between My Settings. My Tune Was Called An Aggressive Street Set Up, All I Know Is Best Bang For My Buck So Far.
I Would Highly Recommend Setting Up Your Suspension For You!
My Bike Handles Like Its On Rails, And Braking Is More Sure, No More Nose Dive.
Hope This Helps!
