does anyone have the instructions to rebuild the front brake master cylinder for an 05 636. I have the rebuild kit but not sure what order it goes in... thanks.
(it was tore apart and missing pieces when i bought the bike)
Discussion Starter #3
I found a manual online. But, just an FYI for anyone else who has to rebuild a front master cylinder a 05 636-c1, as long as the piston is not froze in the cylinder the piston will come right out after you pull out the snap ring. Mine was frozen in their and I had to drill through the piston and use an easy out to break it free and that was after I sprayed it with some penitrating oil. Cleaned it and put it all back together, bled the MC and calipers and now it stops on a dime.
