Yes these are lowering links. Can't tell without measuring a factory one to compare.
Looks like a coolant container. Keep the level between the upper and lower line. Yours is low and could use a flush. Is there a hystory of a leaking head gasket?
This is an airbox drain, most of the time it should stay clear.
FYI it's easier to answer questions when the pics are imbeded in your thread.
cheers
cheers[/QUOTE]
i tried for some reason said they were to big thats the only way that worked
When using photobucket just copy the IMG code.
cheers
Sauceman is right on all accounts. Looking at the links...I'd say your bike is lowered.
No if the link is in top hole then is is set as high as it goes if it's in the bottom it is as low as it goes trust me I've done it
Sent from my iPhone using MO Free
