Okay when i push start it will crank . but if it doesnt start and i hit the start again it does nothing. Until i turn key off and back on. Then it will crank. Why is this
I would suspect a failing starter relay at first. My zx7 did a similar thing years ago. However, it could also be corrosion in the ignition switch, start button and/or the Killswitch.
Other things to check would be neutral gear, clutch and side stand safety switches. Last, but not least, the starter itself. Though, I've never had the starter fail on my bike. It's always a possibility though. I probably forgot to list something and someone else will chime in
