Hello I'm new to the forum. Just bought a 1999 kawasaki zx9r. As I'm riding and then beginning to slow down and use my brakes I hear a whining noise. It's not really a metallic sound or anything but it sounds like a high pitch zipper noise. I watched you tube videos about my bike and in some videos they have the same braking sound... so I was wondering if that's normal? My brake pads seem to be good so I'm just worried. Let me know... thanks guys
Cant be sure, but you could pull the Calipers, scrub down the disks with Comet cleanser & double check the pads for wear. Personally, I cant stand the organic pads, they are POS in my book, but maybe a semi-metallic pad would be a better choice... Also, pull the speedo gear assy @ the wheel, make sure it looks good to go
If u can pull the front wheel off while ur doing stuff, check the bearings. Long shot perhaps but u could b changing the side load on the wheel bearings and they could b reaching the end. Probably something else tho. But its aging and has unknown care at this point. Just thoughts
I had the same on my ZX 9R after I installed EBC HH brake pads.. I sold the bike about 2 years ago, and the brakes were excellent, very happy with them.
The sound was just as you describe, I got used to it. Loved those brake pads, will put them on my GSX S1000 when the time comes.
I have 2, a 98 and a 2000 and both make this noise. I normally describe as the sounds cicadas make in the summer. Happens with OEM pads and EBC-HH pads. Likely no problem at all but it wouldnt be a bad idea just to check your wheel bearings anyway.
Blain mentioned pulling speedo gear. On this bike the speedo is run from a pulse counter on the countershaft sprocket.
98-99 have 6 pot calipers on the front. If you don't change brake fluid every 3-4 years sometimes one of them will stick. If you didn't get a good history on with the bike I would also recommend a brake fluid flush
