ok, i have a 1996 zx9 that wont start. the motor has been rebuilt with these additions..
1. replaced wire harness
2. replaced cdi
3. replaces junction box
4. replaced ignition switch
5. carbs has been disassembled & cleaned
6. replaced spark plugs(2x's)
7. sidestand switch bypassed
8. fuel pump bypassed for now, gas ran straight thru to bowls
keep in mind, im only tryin 2 start this to hear it run....the bowls have gas in them & i spray starter fluid in the stacks. the choke is 100% open & throttle is open wide. now when i hit the starter button, it turns over & every now & then it will catch & run for a split second or two then dies. i have the wiring diagram from kawasaki to try & eliminate anythin electrical. i read sumthing on the neutral switch but confused on what is what..light green wire & black/yellow bypass to get neutral light on..green/white wire not hooked up to anything & a small 2 prong harness with a yellow wire & black/yellow..dont know where that goes???(will try to upload pics soon). i thought about it being flooded but after sitting for a day or so, it still gives me the same results..nothin..someone please help..spring is soon to be here...
2. replaced cdi
