I have a 1993 Kawasaki ZXR 750 I just picked it up and got it started and well Im not sure what to do. I can start the bike but the idle is so messed up in the begining it runs so high that flames shoot out of the exhaust then when I warm it up and take th choke off it will roughly idle for a second but it will keep kutting off so i rev it a little and it will either bog down or I can get it to rev up but it pops out of the carbs a bit just wondering if anyone has any ideas on where I should start looking first. i dont mind spending money on it I just dont want to fix anything that aint broke....
Ps I am currently a automotive mechanic so i have a great knowledge about the internal combustion engine so feel free to use big words itll confuse the newbies lol......
Banned
Start with K.I.S.S. Keep it simple stupid. Check vac lines, carb sync, and carb cleanliness. I would start with cleaning the carbs and make sure everything is the same across the rack. The pull the bowls and clean clean clean clean..
Yup I am with u on the carb cleaning. A nice good cleaning of the carb and the jets will likely solve the issue. Also invest in some new plugs. Amazingly these can run on 2 plugs! So check spark on each pack.
I am willing to bet 5 or 6 hours of work and some plugs would solve your issue.
Quinton Phuckin Tarantino
These symptoms are usually carb or plug issues as stated above .
Thanks guys actually you all were right the carbs were leaking air on the backside where they mount up to the intake so I removed and reseated them and she purrs now.
