Hey guys.. I'm a noob on here.. I've owned my blue 05 ZX-6R for 2 years now and I just went out to buy some new tires for my ninja.
I bought my tires not checking the size, but I was sold a 120/70ZR17 for the front.. I checked and the OEM size is 120/65ZR17, I called the shop and they said the 120/70ZR17 will work just as good. Is this true? or will I have problems with fender clearance? or other possible issues? Can anyone help me out here?!
I bought the new Michelin Pilot Power 2CT dual compound tires.. hope they are better than the BT-014s!
Here's a list of my current mods...
PCIII, Yoshimura carbon slip on, Puig race screen, OEM Euro side markers, Clear Alternatives integrated tail light.
you shouldn't have any prob with the fender clearance, but watch you leaning!!! I haven't really heared of going bigger in the front and i know u didn't do it on purpose but im sure the same thing kinda holds true for a front tire as a rear. I know if you put a larger tire on the rear your bike WOULD NOT feel the same in the corners. I don't know how long u been riding so if your exp i would say your ok, if your a new rider i would try to return it. if you do keep it be safe
It's ok to do this - everyone does this for any bike w/ a stock 120/65 tire. 120/70 gives you more sidewall (read more traction), but raises the front end, making the bike turn in slightly slower. To compensate, lower your front end 5mm. This is the #1 most common mod to modern sportbikes. Super-easy way to do this is loosen the upper & lower triple clamps and clipons, then take a rubber mallet and gently tap on each side of the upper triple until you start seeing the front drop 1mm at a time. Be careful not to loosen too much at once - it's a trial+ error process that works on every bike I've owned.
That's the info I was looking for. The 2CT's only come in 120/70. I've been trying to work out the geometry which is no small task given my math skills. So, anyone else looking, I'll share what I've found.
Size______Sidewall_____Radius____Diameter____Circumference___Difference
120/65-17......3.1"...........11.6"..........23.1"...............72.7".............0
120/70-17......3.3"...........11.8"..........23.6"...............74.2".............2.0%
I was looking for a formula or something to figure out how far to move the forks but, no luck. Considering a .2" increase in radius, I figured it wouldn't be much.
Leave it as it is! With the Michelins, your bike will handle much better in any case.(Nothing against the Bridgestones, I like them also, the BT015's and BT002's) The slightly larger profile will give you better high speed stability!
