09 zx6r electrical issue
1 reading
4.2K views 2 replies 2 participants last post by  ALBERT55
#1 ·
Hey whats up guys, heres my problem:
Bike was running fine a few months ago, but then one hot day riding to work and splitting lanes, got to the gas station and put gas, then it just didnt wanna turn on.
All electrical died as soon as i pushed the start button. Thought it was the battery so i ended up push starting it after about 20mins of checking fuses and battery terminals. was able to get it going, got to work and sat for about 5hrs, tried turning it on using the button and nothing.
So i pushed started it again, got home and same thing, it died soon as i killed it with the kill switch. Tried to turn it on and nothing.
So i thought i had seen this before and figured it would be the stator. But before i went out and bought it, i bought a new battery, and it fixed it for about 2 months. But now the same thing has happened, charged the battery, tried it and nothing. Now it doesnt even wanna turn due to electrical problems.
I changed the stator and voltage regulator/Rectifier. And still nothing.
Now idk what it could be. This is where you guys come in and school me a bit more on what this could be.
Battery is about 6 weeks old
Stator is new
RR/VOltage regulator is new
Fuses are good
What can it be?
help
heres a link to what the bike does when i turn the key and flip the kill switch off/on
https://youtu.be/ZaIO9K8FdE4
So the speedo flickers on and off when i push the start button
#3 ·
Ok so i checked that relay, and it looked good. It had a little corrosion, but i sprayed it with electrical cleaner and tried it. But the problem persisted. However, i dont think it would be bad because its having a low voltage issue. If it was just the starter relay, it would restrict it from cranking wouldn't it?
Upon inspecting the battery off the bike it was reading 12.5v. But once hooked up, it was reading 10.4v. I tried hooking up the battery charger to it and it was reading ~14v so i tried to crank it and it did crank but i noticed the fuel pump wasnt coming on. So now im stuck a bit more now. Could it be the computer/ecu?
