much to my surprise yesterday after running some errands in the morning I parked the bike in the garage, 3 hours later i smelt the pungent odor of gas while doing some laundry, thought it might have been the weed eater, but then looked and saw gas running down the left side of the frame on the bike... first checked the filler cap, no leak there, then torn the seat off and checked the little house on rear of tank, no leak there... next step began to remove tank and discovered the tank pad was completely soaked with gasoline... the rubber flap covering the head/air box was wet with gasoline as well only on the topside that contacts the tankpad. This is puzzling and i can't find the leak the connection on the underside of the tank is not leaking either, since then i've left the filler cap open to decrease pressure in tank and there hasn't been any signs of further leaking like before... was hoping someone could shine some light on the issue before i bite the bullet and take it to the dealer, it is a full tank of gas with only 30 miles to the tank i'm open to all possibilities
