rode my bike about 25 miles no problem. parked for an hour and rode for another 10 miles then it starts to run funny. if i rev to past 12k it would get to 12 then drop down to about 9k then back up, all while holding the throttle open. it has a fresh tank of gas. no FI light. eventually on my way home it lost power on me twice. any known problems or issues i should check 1st?
check the battery voltage
got a power commander? check the connections on the plugs and on the injectors,
check the plugs.
happened to me and it was running on 3 cylinders. needed a new plug.
Discussion Starter #5
no power commander. battery voltage is fine. its got 17k on it and i have had it since it had 9k ive never done plugs. i will give it a try.
while checking ya plugs, check your air filter a well...
check the side stand switch.
if this part has a problem it causes the bike to shut down and lose power at high rpms, regardless of throttle inputs.
Make a jumper for the plug and see if that takes care of the problem.
It worked for me and I spent a long time chasing it down (nothing in the service manual about this).
