1 - 13 of 13 Posts
Alright my bike will not start it will crank but not fire. The battery did die in the process of trying to start it so i tried to jump it and the same result. I am getting fuel but no spark. I have no voltage going to the coils. I have a spare ecu and no luck with that. The fuel is clean and fresh. The only outside condition was we had a bad thunderstorm ehen i was at work. The bike also had s pcIII and a two bros Exhaust but currently is all stock. Ive changed the plugs and am not getting any codes.. please help
Did you check fuses? There is one for the ignition and one for the ECU.
Also, the crank sensor controls spark, make sure you are getting a signal.
Alright i am now getting voltage to the plugs... but if i ground it to the frame i still have no spark
Ok battery plugs and all sensors checked out ok. I have an extra ecu so i ruled that out as well. How do i check the ignition switch
You get a volt meter and see if there is power going through the switch when in the on position.
Also, you wouldn't happen to have a chipped key would you? There will be a light that flashes on dash when the bike is off if you have it.
Didnt noticed a flashing light when it was off but I will check when I am off work and wouldn't the gage and everything powering up show the ignition switch is working
yeah it would and you said you were getting spark right? so that would mean the engine kill switch is working too.
Discussion Starter · #10 ·
It cranks but i dont get a spark... if the kill switch was bad wouldnt the starter not work?
Well tommorrow i have time to work on it and ill check everything yet again and if nothing then im breaking down and its going to the stealership
Dropped it off today they said they wont get to it for a few days...already been a week with at the bike and im having withdrawals lol
Discussion Starter · #13 ·
K my first$100 of diagnostics went into finding i had no spark...which i already told them. And they said my gas tank was 1/2 full of water
1 - 13 of 13 Posts
