So the engine was just swapped on this motorcycle because the last one was unrepairable. the F1 light turned on and sometimes when i pull to a stop or a light the motorcycle turns off. It still starts back up but i would like to know more about the problem
- I pulled the code 15 atmospheric pressure sensor
i want to know more about this problem, is it serious..? should i not be riding around until it's fixed? what could be causing the failure of this sensor?
thanks guys id appreciate the help
Welcome to the forum. Can't you just switch the sensor out with the one from the old motor?
