Hi. i have a 06 zx636 ninja doing this weird thing only when cold. after temp rise up to 125 degrees problem stop and runs fine. no power commander,no error codes or anything. only modes are a yoshi slip on and a servo eliminator.plugs are new,clean K&N filter. sometimes go as high as 4k rpms then goes down and up untill reach the 125 degrees. any advice will be appreciated.thanks
Normal "choke" function when under "X" temp?
this model doesn't have choke. its supose to be 2k rpms till get an operational sake temp, not up and down from 2k to 4k rpms or more till get warm. i lifted the tank hoping it was a lose hose or something else. loose the throtle cabels a little bit and the idle adjuster too but still the same. also saw theres a rod that comes out from the throtle bodies that moves and push while doing the up and down thing as it were pulling from the throtle cables. anyways thanks for the reply
