Hey guys, got this 06 636 and the problem is with the clutch
The problem is going from N to 1st bike jerks forward like its still in gear, doesn't die just jerks a little. Also when going to a stop I can hear the clutch make a noise in neutral.
Too me, sounds like a sticking plate, the owner before me says it hasn't ran for a couple of months and oil was also pretty dirty when I did a change.
I'm use too the 750s where it was hydro clutch and such.
Just trying to get a opinin and where to go from here.
Thanks
Depends how much it jumps for starters. And how the clutch is actuated doesn't change how the clutch works, so there shouldn't be a big difference between cable and hydraulic.
I have a similar problem. Only mine I think is a clutch not fully disengaging. In gear with clutch pulled all the way it will still move forward and I have to hold brake. Sucks at stoplights cuz if I don't get to neutral before I stop I can't get it out of gear and I have to fight it from rolling into a car in front of me. Pretty sure it's cuz the clutch is so worn I have it adjusted all the way out. But have a new clutch on the way so hopefully that fixes it
Sent from my iPhone using MO Free
