Has anyone experienced this I can ride all the way from fall to the end of spring but when it gets hot ( over 90 degrees) the bike gets to got in town and shuts off can someone offer a direction to look. I've changed the coolant and replaced the water pump seals.
Similar thing happened to mine when I bought it. I dropped it and I noticed the fan wasn’t turning on. It still runs hot, like 225 and up until it says “hot” sometimes. I checked all wires and sure enough the fan connector was loose. ?
My fan comes on. But I’m having heat issues too. Changed coolant, new thermostat, buying a new water pump. If it sits at a light, it heats up quick.
I've seen this issue is related to the ECU. If your ECU gets fried from your exhaust, then you'll have to buy a new ECU. Not from my experience, just research I've done.
Hi I’ve got a blackbird very well none for running hot ,I changed
Coolant
Thermostat
Rad
It turned out just to be the rad cap wasn’t pressurising changed it
Now runs so cool
