what year 12r shock did u buy? does it matter? post some pics when u get it installed.
I'd be interested in doing the same to my 92 as long as it can be swapped back.....?
Any year. The 00-01 has slightly different valving than the 02+, but in all reality nobody would know. If it looks good buy it.
And you shouldn't have to modify anything on the bike, with the exception of "maybe" having to raise the battery box. Even that is a stretch.
For example, on my 93 I have the ride heght adjuster max to the cotter pin and the 12R reservoir just cleared the bottom of the battery bracket and tray. If you guys ride with the ride height in the stock location you may have issues. Easy solution there is to just crank the ride height.
With the 12R shock you'll need to drill out the upper and lower mounting holes to 12mm. The lower holes are thru aluminum and are easy, the upper is hardened steel, but not an issue.
Josh
