Is it possible? I am redoing my transmission because I lost 3rd all together. I heard somewhere that a 2000 transmission would work in a 99 gearbox, I know they have undercut 3rd and 4th and have a better shift drum. Basically everythig is a better design in the 00's so why not upgrade.
Thanks
John
all i can say is if you change any thing change over everything... as far as this working i'm not sure, if the OD of the shafts are the same and the OD of the drum is the same it might work but i think you would be better off just getting the 99 parts and having the gears undercut your self and not worry about if it will work or not.
