kawasaki 2000 zx9r
no you will need the 2002-03 seat and subframe. the 2000 seat is totally different, plus the battery box and tail section compartment and all the seat brackets,.note the bracket that holds the seat down is discontinued so you'll have to make one, (I have spare brackets for the seat if you need) after all that now the wiring harness has to be flipped, the rectifier is on right side and the ecu is on the left. the fuse box is ok and turn signal/brake harness ok. any other questions let me know, also I sourced the seat In a motorcycle junk yard in Amsterdam, there hard to find in the u.s.
