Running like garbage. - ZX Forums
post #1 of 8 (permalink) Old 05-22-2019, 03:48 PM Thread Starter
tempist23's Avatar
Bike is running like its on three cylinders. Sounds horrible. Swapping out plugs, air filter and fuel filter. Going to look at the carb, its all original with only 5k on the bike. So I am guessing a rebuild kit may be in order. Do you all have any other thoughts to look at.?
tempist23 is offline
post #2 of 8 (permalink) Old 05-23-2019, 02:45 AM
yorkie's Avatar
I Ride: Blue 9C2, 12B4
Check the resistance through the Kill Switch as any resistance in there will drop the voltage to the stick coils when they fire, just checking the voltage at the stick coils will not help as it will show battery voltage and only when the coil fires will the voltage drop, but this will be too quick for you to notice.
yorkie is offline
post #3 of 8 (permalink) Old 05-23-2019, 05:59 PM Thread Starter
tempist23's Avatar
Thanks, I ourchased all the stuff to redo the tune up, plugs, filters....etc...etc... Ill also check the coils.
post #4 of 8 (permalink) Old 05-23-2019, 07:39 PM
taildragger1197's Avatar
I Ride: a quicker bike than yours.
Garage
Telling us that the bike is "running like garbage" doesn't give us much to help you diagnose the problem. Does it idle properly? Will it take throttle input? Where in the power range does the problem seem to worsen? Have you checked for wet/fouled plugs? May be as simple as a plugged jet/jets.
taildragger1197 is offline
post #5 of 8 (permalink) Old 05-24-2019, 02:18 AM
I had similar issues, idling on three cylinders but picking up after about 3k rpm. I took cylinder out one by one by taking the coil off to figure out wat cylinder was not firing, cleaned idle circuit on the carb and runs fine now. Might also want to look for vacuum leaks. Two years ago had similar issues but the cause was too much gas because one carb was flooding with gas. I diagnosed this by hotwireing the fuelpump, if it keeps pumping for more than about 10 seconds or you start to see gas seeping trough somewhere that's your issue.
BEHINDER is offline
post #6 of 8 (permalink) Old 05-24-2019, 04:42 AM
Turbo329's Avatar
I Ride: 2002 ZX-7R; 1998 ZX-7R; 2005 MV Agusta F4 1000S 1+1; 2016 Ninja H2
I would start with a complete carb overhaul and then a carb sync.
1998 ZX-7R (779cc)
- November 2015 BOTM
- 2015 2nd Place BOTY
That's what I like about you, Turbo. Instead of looking to external factors you consistently look to yourself to provide the improvements first.
"I can't corner the way I want to, I'll improve that."
"My bike feels heavy, I'll lose weight."
In a day and age where everyone's playing the blame game and looking for excuses it's refreshing to see a little discipline, determination, and self-efficacy.
ZX7RJoe
Turbo329 is offline
post #7 of 8 (permalink) Old 05-25-2019, 01:58 PM Thread Starter
tempist23's Avatar
I checked thw plugs, they were wet and fouled, a carb clean it is. Its an older bike and I am guessing the carbs have not been apart. I was thinking the rebuild kit with all new seals instead of just the clean?
post #8 of 8 (permalink) Old 05-25-2019, 02:00 PM Thread Starter
tempist23's Avatar
Thanks for all the info really appreciate it
Similar Threads
01 zx6r runs like garbage yellowdart312 ZX-6R Forum 6 02-26-2014 07:48 PM
"like Father Like Son" martintr Pictures 12 06-30-2009 03:15 PM
Like Father Like son shaun0169 ZX-6R Forum 15 06-01-2009 12:15 PM
