Installing the ZX9 engine in my ZX7 frame - problem! - ZX Forums
 5Likes
post #1 of 34 (permalink) Old 03-24-2019, 07:19 AM Thread Starter
MickeZX7R's Avatar
I Ride: 2xZX7R, 1 ZX9 engine
I have fastened the lower rear engine mount, and begun to raise the engines front up against the upper mounts, when...the engine gets in contact with the frame!
Se the attached picture:
Click image for larger version
MickeZX7R is offline
post #2 of 34 (permalink) Old 03-24-2019, 07:26 AM
mte78's Avatar
I have never seen a ZX9R B motor mounted to a ZX7R P model.
Maybe try contacting BRG Racing and see if their mount kit will work with this application?
mte78 is offline
post #3 of 34 (permalink) Old 03-24-2019, 07:27 AM
mte78's Avatar
mte78 is offline
post #4 of 34 (permalink) Old 03-24-2019, 08:11 AM
57x
7777
57x's Avatar
It is tight. You cannot install the frame that way when you have a 9 engine. Do not install any bolts until it is close. You have to put it more straight over the head. There is some swearing involved but it fits.
57x is offline
post #5 of 34 (permalink) Old 03-24-2019, 10:02 AM Thread Starter
MickeZX7R's Avatar
- Ah, i see. I will try that one instead then. Thankīs for your input 57x : )
I read at more then one site that the installation should be:
"first mount the lower rear, and than jack the front up until it reaches the upper mounts".
post #6 of 34 (permalink) Old 03-24-2019, 10:24 AM
57x
7777
57x's Avatar
That works fine if you do not have a 9 engine. Both the early and late 7 frames just don't have the space to do that.
MickeZX7R likes this.
57x is offline
post #7 of 34 (permalink) Old 03-24-2019, 10:30 AM Thread Starter
MickeZX7R's Avatar
- Iīve read several threads with this done on P models. Maybe itīs just more "bolt-on" with the older ZX7īs.
post #8 of 34 (permalink) Old 03-24-2019, 10:52 AM
57x
7777
57x's Avatar
It's easy on the 91-95. Oval the hole in the head during install
96+ has lots of complications.
- Oil return on left side of head interferes with the frame
- Head bolts need adapters
- Figure out a solution for the airbox since the carb spacing is different and ram air configuration.
The BRG kit and the work is done. The kit is expensive and you have to deal with BRG (I'm not a fan of these guys if you can't tell). Other people tackle these issues themselves.
57x is offline
post #9 of 34 (permalink) Old 03-24-2019, 11:28 AM Thread Starter
MickeZX7R's Avatar
- This is how to deal with the P model issues without BRG, according to one of the many threads:
"First off the rear engine mounts line up perfectly as does the sprocket. That just leaves the front engine mounts. If you don' t want to go the BRG route, you can get around the front engine mount problem by wittling out the other engine mounting holes on the engine, this will give enough movement to install all the mounts on the standard frame.
Second up is the oil delivery pipe to the cylinder head. This will require a little frame modification in order to clear the banjo bolt.
Third up is the airbox, in order to use the 9r carbs try to get hold of a 9r B base for the airbox, the carb mounting face is then cut out and plastic welded (using soldering iron) into the base of the 7r airbox. this allows the use of 7r airbox with filter and ram air tubes."
post #10 of 34 (permalink) Old 03-24-2019, 12:43 PM
I've been struggling with this for a few months , the easiest way is to use some ratchet straps from a strong bar in the the roof trusses and crank the motor up but get the front of the motor up then rear alternating , the motor needs to be tipped back from it's normal position until you can get the rear mounts in then raise for front mounts , what you will find is the front right mount will be fine but the left is a mile out (2-3 cm ) no amount of wittiling will work you will either need to take the bgr route or make some sort of bracket yourself and I can tell you it ain't easy you got next to no room there, another thing is the oil feed will not work there's not not enough Clarence to pass the frame so it's either but or make something yourself (again not easy) , good luck are you in the UK? The trouble I've found when looking for advice is that people are giving advice on their experience with the older jklm models and not the p which I understand is a much easier nearly plug and play
zxfliddyr is offline
post #11 of 34 (permalink) Old 03-25-2019, 08:31 AM
Hammerhead's Avatar
I Ride: '07 ZX-14
7 of 9
Hammerhead is offline
post #12 of 34 (permalink) Old 03-25-2019, 11:58 AM Thread Starter
MickeZX7R's Avatar
I now wonder one thing - should the black engine rack stay on the ZX9 engine or be removed when mounting it into the ZX7?
post #13 of 34 (permalink) Old 03-25-2019, 12:25 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
Now why would you suddenly think of a rack?
post #14 of 34 (permalink) Old 03-25-2019, 01:39 PM
ninjanut's Avatar
Will not mount up to ZX7 frame so just leave it off. Serves no purpose other than added weight.
ninjanut is offline
post #15 of 34 (permalink) Old 03-25-2019, 11:32 PM Thread Starter
MickeZX7R's Avatar
- I just wanted to make sure that i hadīnt misunderstood anything about that rack mounted to the ZX9 engine initially, before i proceed with this conversion : )
post #16 of 34 (permalink) Old 03-25-2019, 11:34 PM Thread Starter
MickeZX7R's Avatar
- Thankīs for your input : )
I saw this on another forum, as posted earlier in this thread, the things that has to be modified is the banjo bolt for the oil delivery pipe, and the airbox (and i have the box from the 9):
"..If you don' t want to go the BRG route, you can get around the front engine mount problem by wittling out the other engine mounting holes on the engine, this will give enough movement to install all the mounts on the standard frame. Second up is the oil delivery pipe to the cylinder head. This will require a little frame modification in order to clear the banjo bolt. Third up is the airbox, in order to use the 9r carbs try to get hold of a 9r B base for the airbox, the carb mounting face is then cut out and plastic welded (using soldering iron) into the base of the 7r airbox. this allows the use of 7r airbox with filter and ram air tubes."
post #17 of 34 (permalink) Old 03-26-2019, 11:11 AM Thread Starter
MickeZX7R's Avatar
So..what do one do with this oil banjo-frame contact situation?
"a little frame modification" - does that mean dremel work on the frame?
Name:	oil banjo.jpg
post #18 of 34 (permalink) Old 03-26-2019, 11:51 AM
57x
7777
57x's Avatar
I'm not a fan of cutting up a frame up clearance this. It is why you hear me and others mention the BRG kit. It's expensive but it works.
You don't have to buy the whole kit. Just pick and choose what you want out of the kit.
57x is offline
post #19 of 34 (permalink) Old 03-26-2019, 12:11 PM Thread Starter
MickeZX7R's Avatar
- I canīt see how one can pick separate parts of that kit, just the complete kit?
https://brg-racing.myshopify.com/pro...9conversionkit
post #20 of 34 (permalink) Old 03-26-2019, 01:53 PM
57x
7777
57x's Avatar
Send them an email
57x is offline
Similar Threads
Installing a zx9 engine into a zx7 Abd775 General Discussion 2 09-03-2017 12:59 PM
Installing Frame sliders ezriderkz ZX-14 Forum 5 10-07-2009 04:11 PM
help - replace ZX9 '98 engine with ZX9 2000 engine - sensor problem with camshaft Smokey900 Mechanical & Technical 0 06-11-2009 10:05 AM
Installing Frame Sliders K-PASA07 ZX-6R Forum 12 04-13-2009 10:44 AM
Web Help? Installing Frame Sliders? james1300 Mechanical & Technical 6 03-15-2006 10:49 PM
