Let's establish a ZX7 Carb settings database - ZX Forums
 3Likes
post #1 of 129 (permalink) Old 04-30-2013, 05:13 PM Thread Starter
2fat2fly's Avatar
Garage
I'd like to establish a database of carb settings for ZX7's, ZX7R's & ZX7RR's to help everyone with carb issues. I'd like to see everyone who knows how their carbs are set up post the following info:
1) Year & model of your bike
2) What carbs are on it
3) Carb settings (all of them you know)
Stock or jetted?
Pilot jet size
Main jet size
Needle setting
Mixture screw setting
Air jet sizes(fcr's)
Accelerator pump setting (fcr's)
Air filter
Idle speed
4) How does it ride? Any flat/dead spots
5) Air filter
6) Spark plugs (Brand and Number; example: NGK CR9E)
7) Engine mods
8) What exhaust are you running?
9) Your altitude above sea level
10) Where are you located( Country,State,Province)?
11) Optional: post a picture of the bike you're referring to.
I will be posting mine and I've done it several times to help others in the past. I'd really like to get a solid database together for everyone to be able to draw from when they have issues.
My Turbo ZX12R Build:
https://www.zxforums.com/forums/zx-12...ave-today.html
My 1993 ZX7R (M1)
https://www.zxforums.com/forums/zx-7r...r-real-m1.html
https://www.zxforums.com/forums/zx-7r...-m1-naked.html
2fat2fly is offline
post #2 of 129 (permalink) Old 04-30-2013, 05:39 PM
JoelKnauber's Avatar
I Ride: 2000 ZX7/9R, 2010 CBR1000RR, 2005 KX250F
1) 2000 ZX7R
2) STOCK CVK
DynoJet Jet kit
Stock pilots 2.5 turns
136- 138-138-136 mains
3rd Needle Clip setting. 1 .5mm Shim on each.
Floats at 14mm (I Think)
Idle speed at around 1400.
4) Small flat spot at around 4.5k at WOT that comes to most with aftermarket headers. After/before that this thing is a beast.
5) Uni Air filter
6) NGK CR9E
7) Micron Full exhaust with akrpovoik titanium can
"float bowl mod"
Race air intakes.
Crankcase vented to atmosphere.
+2 ignition advance
8) Around 750 Feet
9) Northwest Wisconsin
Spending too much time to make a bike faster than it really needs to be.
https://www.zxforums.com/forums/zx-7r...thread-23.html
JoelKnauber is offline
post #3 of 129 (permalink) Old 04-30-2013, 05:49 PM
92Ninjas's Avatar
I Ride: '93 "zx7" REobtainium
1) 1993 Kawasaki Zxr750 L1 (wrecked Zx7)
2) Stock Keihin 38mm
Jetted - Stage 2 dynojet
Stage1 Fuel Pilots
Stage2 Fuel Mains
Stock Needle setting
Mixture screw setting - 2.25 turns out
No Air filter, Shop Rag at the end of Ram-Air intake
Idle speed ~1k
4) How does it ride? Any flat/dead spots -Rode Like a Bat out of hell. No flat or dead spots that I could exploit
5) Air filter -What?
6) Spark plugs - Autozone/Advanced discount auto store: AutoLite equivalent to CR9E
7) Engine mods - Stock
8) What exhaust are you running? - Open with an exhaust tip added on
9) Your altitude above sea level - @sea level
10) Where are you located( Country,State,Province)? USA, FL
11) Optional: post a picture of the bike you're referring to. Its in my album
Sir Rag Filterin', Long Ass Waitin', Assless PJ Wearin' Post Whore of ZXF
1993 "zxr750" REobtainium
1996 zx7r P1(aka Zombiehorse)
1993 zxr750 L1(Totaled/donor bike)
2010 250R(Voluntary Repo..)
1992 zx11(Sold)
I don't have any friends so I would have to vote,
1 - I like to do it all by myself
92Ninjas is offline
post #4 of 129 (permalink) Old 04-30-2013, 06:19 PM Thread Starter
2fat2fly's Avatar
Garage
1) Year & model of your bike? 1993 ZX7R
2) What carbs are on it? FCR 39mm Flatslides
3) Carb settings (all of them you know)? Refer to pictures.
Stock or jetted?
Pilot jet size
Main jet size
Needle setting
Idle speed? 1,250rpm
4) How does it ride? Any flat/dead spots? Rides like a pissed off bullet on a mission!
5) Air filter? Stock? 6) Spark plugs (Brand and Number; example: NGK CR9E)? NGK CR10E
7) Engine mods? Ex AMA Privateer Superbike. Degreed cams,thin head gasket, ported head, higher compression pistons.
8) What exhaust are you running? Hindle High Pipe
9) Your altitude above sea level? 1,045 ft
10) Where are you located( Country,State,Province)?Ohio
My 1993 ZX7R (M1)
2fat2fly is offline
post #5 of 129 (permalink) Old 04-30-2013, 07:02 PM
Patiently waiting for 1992 FCR settings...
F2blwn408 is offline
post #6 of 129 (permalink) Old 04-30-2013, 07:04 PM Thread Starter
2fat2fly's Avatar
Garage
They're almost identical to my 93's. I will post them when I dig them back up. Hopefully others will post their settings so we have a very good cross roads of settings to study and learn from.
My 1993 ZX7R (M1)
2fat2fly is offline
post #7 of 129 (permalink) Old 04-30-2013, 07:19 PM
Slow air screw...
Pilot screw...
Same?
There is only one thing on my carbs that I can turn and I believe it to be the "pilot screw".
Nevermind... I guess stock the "slow air screw" is a jet originally.
post #8 of 129 (permalink) Old 04-30-2013, 08:08 PM
92Ninjas's Avatar
I'm waiting on sudco 39mm settings for the new 7 I have. I want to fine tune the s.o.b's better than what they are currently at
1992 zx11(Sold)
92Ninjas is offline
post #9 of 129 (permalink) Old 04-30-2013, 09:05 PM
I Ride: dicks mostly
1) 1993 ZX7L1
2) Stock CVK
Stock or jetted? Stock
Pilot jet size: Stock
Main jet size: Stock
Needle setting: Stock
Mixture screw setting: 2.25 turns out
Air filter: K&N panel
Idle speed: ~1250
4) How does it ride? Very very well. Best running bike between all of mine
5) Air filter: K&N Panel
6) Spark plugs (Brand and Number; example: NGK CR9E) Unsure
7) Engine mods: Blocked off valve cover emissions, tube from carb vents directly into air box.
8) What exhaust are you running? OEM ZX9 header (with equalizer pipe between all 4 header tubes) & can.
9) Your altitude above sea level. 60ft/18m
10) Where are you located( Country,State,Province)? Massachusetts
Should we add float setting?
Read me; you'll probably regret it.
http://oneguytwowheels.blogspot.com/
1989 Kawasaki ZX7-H1
1998 Suzuki GSX-R750 x2
1993 Honda CBR900RR
1994 Honda CBR900RR
1985 Honda VF1000R
I think that's all of them?
Garrett is offline
post #10 of 129 (permalink) Old 05-01-2013, 05:10 AM
ZX7RJoe's Avatar
I Ride: 2002 ZX7R, 1994 ZX7 (Sold)
I propose yes, absolutely.
ZX7RJoe is offline
post #11 of 129 (permalink) Old 05-01-2013, 05:21 AM Thread Starter
2fat2fly's Avatar
Garage
Good idea.
My 1993 ZX7R (M1)
2fat2fly is offline
post #12 of 129 (permalink) Old 05-01-2013, 06:15 AM
Banned
I Ride: A warhorse H model ZX7, 93 ZX7/9
This will take a while..
1) 89 zx7
2) 38mm cvk from a 90
3) Jetted FP
Pilot jet size:#36
Main jet size#145
Needle setting 3rd from top
Mixture screw setting 2 turns
Air filter BMC
Idle speed 850
Smooth power all the way till 7k then hang on.
5) BMC
6) Spark plugs: NGK CR9E
7) Engine mods Muzzy race cams with adjustable gears 102/102 kleen air mod.
8) What exhaust are you running? Full Muzzy with yosh slip on
9) Your altitude above sea level: 0'
10) Where are you located: Florida
[IMG][/IMG]
94 ZX7
FP jetting on stock cvk's
#36 pilot jets
#165/172 mains
3rd clip from top
floats 14mm
K&N filter
Full Muzzy Ti system
slight over bore
NGK C9RE plugs
Runs great through out the RPM range.
[IMG][/IMG]
christikitty is offline
post #13 of 129 (permalink) Old 05-01-2013, 05:28 PM
Kawzxr9's Avatar
I Ride: 1993 ZX7(950), 2003 ZX9R
91-94 ZX7R (39mm OEM Flatslides) as per Ken Water's tips
OEM Kawasaki flatslides bored out to 41 mm jetted as follows,
Needle OCFHP sudco, 4th clip position
Nozzles, purge or Primary, main air jet 200
Mixture screws 1 1/2 out
120 slow air, or 1 1/2 on screw if equipped with..
45 slow air or pilot jet
138 main jet, hex jet not small round jet
I run CR9EK Spark plugs
1992 ZX6D
1993 ZX7 (950 bigbore)
2003 Yam. Zuma 49cc
2003 ZX9R
Kawzxr9 is offline
post #14 of 129 (permalink) Old 05-12-2013, 12:39 AM
FCR users...
What nozzles are you using?
Stock (small holes)
Sudco (large holes)
Main Jet Type...
Stock (round)
Sudco (long hex)
Both accelerator pumps or one?
(OEM) FCR's users only
post #15 of 129 (permalink) Old 05-12-2013, 04:55 AM
Kawzxr9's Avatar
VERY surprised guys aren't running NGK-CR9EK's for plugs.
Dual electrode suppose to burn cleaner= more power.
1992 ZX6D
2003 Yam. Zuma 49cc
2003 ZX9R
Kawzxr9 is offline
post #16 of 129 (permalink) Old 05-12-2013, 07:09 AM
Turbo329's Avatar
I Ride: 2002 ZX-7R; 1998 ZX-7R; 2005 MV Agusta F4 1000S 1+1; 2016 Ninja H2
Finally got my '02 running great!
1) Year & model of your bike - 2002 ZX-7R
2) What carbs are on it - Stock Keihin CV Carbs
3) Carb settings
Float Height set to 15mm for warm weather riding (could probably go for 14mm)
Stock or jetted? - DynoJet Stage 1
Carb Slide Lift Holes drilled (enlarged) with #32 drill bit
Pilot jet size - Stock
Main jet size - 132, 134, 134, 132
Needle setting - clip on 4th groove
Mixture screw setting - 3 Turns out from full clockwise (Pilot Screw)
Idle speed - 1,300 - 1,400rpm (think I need my fuel filter changed)
4) How does it ride? Any flat/dead spots (slight fluffyness at 2-3k rpm range. Crisp everywhere else
5) Air filter - OEM Replacement
6) Spark plugs - NGK CR9E
7) Engine mods - N/A
8) What exhaust are you running? - Micron Bolt-on
9) Your altitude above sea level - Hurricane Sandy. 'Nough said
10) Where are you located( Country,State,Province)? - Queens, NYC
1998 ZX-7R (779cc)
- November 2015 BOTM
- 2015 2nd Place BOTY
That's what I like about you, Turbo. Instead of looking to external factors you consistently look to yourself to provide the improvements first.
"I can't corner the way I want to, I'll improve that."
"My bike feels heavy, I'll lose weight."
In a day and age where everyone's playing the blame game and looking for excuses it's refreshing to see a little discipline, determination, and self-efficacy.
ZX7RJoe
Turbo329 is offline
post #17 of 129 (permalink) Old 05-12-2013, 06:48 PM
1) 1992 ZX7R
2) OEM 39MM FCR flatslides
3) Carb settings...
Pilot jet size-45
Main jet size-1&4=135/2&3=138 (stock round main)
Needle setting-OCFMP 1&4=4th from top/2&3=5th from top (Sudco nozzles)
Mixture screw setting-1.5 out
Air jet sizes-slow air=120/main air=1&4=200/2&3=195
Accelerator pump setting-stock, disconnected the left side
Air filter-stock
Idle speed-1200
Just took it out for a spin and it almost ripped the bars from my hands in 2nd!!
5) Air filter-stock... Hey this is on the list twice! lol
6) Spark plugs NGK CR9E, going to try some EK's
7) Engine mods-stock
8) Full Ti Muzzy
9) Everything is sea level in Hawaii!
10) Where are you located-Wahiawa, Hawaii
Still going to mess with it a little, BUT that larger main air jet is the key!!!
I had a 100 in there before and it ran like shit. Im afraid I may rack up the mileage now since it runs so good!
post #18 of 129 (permalink) Old 05-12-2013, 07:21 PM
Renegadetattoo's Avatar
You know, if someone within the forum knew a bit about php, a database could be made that is searchable by any parameter. That having been said:
95 zx7
FP jet kit titanium with different needles on inner and outer, mains are same across the board.
Mains:180
Idle:factory
Needles: second from bottom
Floats: 14.5mm
Kleen air mod..float mod
Full titanium muzzy
No screen and k&n filter
Carbs came with dyno junk , removed plugs and plugged drilled holes in slides.
Started with Fp recommended 190 mains, was too rich, dropped to 180. Kit came with 180,190 and 200.
Started with 3rd clip pos as per Fp
I will go over my float setting and findings as this may help others.
13mm: too rich, wot at low rpm caused bike to bog down and try to die.
15.5mm: too lean, bike needed choke to start even when hot.
14.5 mm: bike accepts wot at low rpm and starts easily when hot without choke or touching throttle.
Screws are at 2 turns.
After all settings bike seems at the best I've had it so far. Doesn't want to wheelie per say, or pull so hard it wants to come out from under me but I did light the rear tire up in second gear rolling at about 20-25 mph when I got on it hard so I take that as a good sign.
Sent from Motorcycle.com App
Renegadetattoo is offline
post #19 of 129 (permalink) Old 05-12-2013, 07:56 PM
92Ninjas's Avatar
I heard the dual electrodes were good for low-mid rpm ranged bikes but not high rpm sportbikes because of how rapid the spark plugs fire. This is what I've heard. What's your experience with them?
1992 zx11(Sold)
92Ninjas is offline
post #20 of 129 (permalink) Old 05-15-2013, 01:40 PM
I Ride: ZX7RR N1
96 ZX7RR
38mm CVK
Pilot jet size
40 (keihin size)
Main jet size
168, 178, 178, 168 (keihin sizes)
Needle setting
1 factory pro shim under each needle
2.5 turns out
Emulsion Tube
Factory Pro emulsion tube
Vacuum Slide Springs
Factory Pro vacuum slide springs
Float height
15mm
Idle speed
1400
Flat spot off idle between 1500-3000 rpms. Very smooth everywhere else. Delightfully smooth 4-6k rpm cruise. Slightly buzzy at high RPMs (above 10k) but pulls strong.
5) Air filter
K&N
CR9E
7) Engine mods
+4 advancer
Full hindle
100m above sea level
Canada, Ontario
sixstring is offline
