Kleen air/float mod - ZX Forums
post #1 of 9 (permalink) Old 02-19-2013, 06:27 AM Thread Starter
bcurrier2's Avatar
Kleen air/float mod
Morning all.
The bike is a 99 zx7r.
Slip on d+d
K&N air filter.
170/180 jets with 35 pilots.
1 shim under needle.
Screws at 1 3/4 out.
I have the bike apart right now while waiting for a shim kit. While its there I'm considering doing the Kleen air / float bowl mod. My question is will this require smaller jets?
I have gotten tons of info from this and other forums and this mod has mixed reviews. Is it even worth doing?
Thanks in advance.
I know is says Kleenex mod. I couldn't figure out how to edit topic. Sorry
Sent from Motorcycle.com Free App
bcurrier2 is offline
post #2 of 9 (permalink) Old 02-19-2013, 08:52 AM
Avi
I Ride: ZX7R 98
hi
first a disclaimer I am only getting the full system in a week and haven't touched anything other yet. however, as far as said on this forum, the kleen air mod has nothing to do with the carbs or air/fuel mixture for obvious reasons,but the float valve does, and will require smaller jets.
I do want to ask you what shims are you using for the carb needles?
I am gonna get a similar setup and need a starting point until I get a jetting kit.
Thanks,
Avi
Avi is offline
post #3 of 9 (permalink) Old 02-19-2013, 10:43 AM
e1_ZX-9r's Avatar
Thanks,
Avi
$0.59/set of 4 fiber washers @ Home Depot in their specialty drawers. Splurge and get two bags. You can afford it. ZXF Thread <here>
Alright! Trading bikes for a while was fun.I'm ready for mine back. No, seriously, get off my bike. Ahh, what a privilege it is to have such a sweet ride.
At the track she's said to be outclassed, but on the street, she reigns unmatched. She's the only big-bore canyon carving hypermiler I know of. -- Picture gallery, K&N air filter, SuperTrapp Aluminum Racing Series exhaust (Made in USA), ZG touring shield, & otherwise stock.
Science & OODA literate. ACA covered.
e1_ZX-9r is offline
post #4 of 9 (permalink) Old 02-19-2013, 01:17 PM
ninjanut's Avatar
Originally Posted by bcurrier2 View Post
Morning all.
Slip on d+d
K&N air filter.
Thanks in advance.
Is it worth it? Sure, it doesn't cost anything and takes minutes to do. You save a bit of weight/clutter and pressurizes the bowls properly. It isn't done as a performance mod that will yield H/P. You will not need to re-jet as a result of the mod either.
ninjanut is offline
post #5 of 9 (permalink) Old 02-20-2013, 06:19 AM Thread Starter
bcurrier2's Avatar
Kleen air/float mod
I'll try the mod out. What about my fuel screws and floats? Should either one of those be adjusted?
Thanks
post #6 of 9 (permalink) Old 02-20-2013, 11:42 AM
ninjanut's Avatar
Probably will not be required. Also depends on where the floats are set now?? Usually the fuel screws are somewhere around 2 turns so you are in the ballpark. Do the mod and then see how it runs/feels. You may need to fine tune the settings.
ninjanut is offline
post #7 of 9 (permalink) Old 02-20-2013, 10:21 PM Thread Starter
bcurrier2's Avatar
Kleen air/float mod
Thanks for the advice. I can't wait to ride. It's cold here in Ontario.
post #8 of 9 (permalink) Old 02-21-2013, 11:38 AM Thread Starter
bcurrier2's Avatar
Kleen air/float mod
My floats are at 11.5 mm
post #9 of 9 (permalink) Old 02-22-2013, 01:24 PM
ninjanut's Avatar
Float height should be around 14-15mm or so. I actually set the fuel levels myself so my floats end up 15-16mm. Most guys seem to set float heights, I just have always used the fuel level method for accuracy.
ninjanut is offline
