Speedo Cable Pic? - ZX Forums
post #1 of 16 (permalink) Old 02-01-2013, 02:39 PM Thread Starter
I Ride: 2003 ZX7R
Speedo Cable Pic?
So I'm riding today since it's an absolutely beautiful riding day and about 50 degrees out. I was doing around 40mph and decided to take a quick glance down to see if I was correct and according to my speedo, I was doing 0mph. lol Got to a red light and looked to the left of the cluster and there was the speedo drive cable. lol Does anyone have a picture of how it attaches to the cluster? I want to figure out if it's broken or came loose somehow before I take the front down to try to figure it out.
SpeakerBox is offline
post #2 of 16 (permalink) Old 02-01-2013, 02:42 PM Thread Starter
I Ride: 2003 ZX7R
I know, I know, I should've taken a picture and posted it and you guys could've told me if it was broken but I had to drop the bike off at home and pick up the girlfriend and she doesn't ride with me right now and I completely forgot.(we recently found out she's pregnant! (-: )
post #3 of 16 (permalink) Old 02-01-2013, 06:34 PM
it just screws onto a fitting on the rear of the cluster. And yes, it is fairly common for them to vibrate loose and disconnect. You should be able to get it back on with a couple of fingers, and it will hold until you decide to pull the front cowl.
Bozo is offline
post #4 of 16 (permalink) Old 02-02-2013, 06:44 AM Thread Starter
I Ride: 2003 ZX7R
Awesome, that's exactly what I wanted to hear. I'll have some time tomorrow to take a good look at it and do what needs to be done until I pull the front cowl. Guess I'll add that to my list when I take it apart to put my race fairings on it after I do a bit of repair and paint work on them. Thanks bro.
So this got me thinking a bit. What do other bikes with digital speedo's use instead of a cable like on the zx7 and older bikes?
post #5 of 16 (permalink) Old 02-02-2013, 06:57 AM Thread Starter
I Ride: 2003 ZX7R
Has anyone used something like this to convert over to a digital speedo gauge?
http://www.dakotadigital.com/index.c...rod/prd242.htm
post #6 of 16 (permalink) Old 02-02-2013, 08:09 AM
JoelKnauber's Avatar
I Ride: 2000 ZX7/9R, 2010 CBR1000RR, 2005 KX250F
You don't have to pull the cowl, I did that on the side of the road a couple times before I ditched my speedo. You can just reach in there and thread it back on, NBD. If you want, throw some loctite on there to make sure it doesn't happen again.
Digital speedos are usually driven by a sensor on the front sprocket, or a hall effect on the front wheel. The trouble with trying to use the stock cable is that turn ratios and what not come into effect, and not all bikes are equal.
Spending too much time to make a bike faster than it really needs to be.
https://www.zxforums.com/forums/zx-7r...thread-23.html
JoelKnauber is offline
post #7 of 16 (permalink) Old 02-02-2013, 09:04 AM Thread Starter
I Ride: 2003 ZX7R
Would doing the conversion get me somewhat close? Has anyone done it successfully and it being accurate or at least close?
post #8 of 16 (permalink) Old 02-02-2013, 09:17 AM Thread Starter
I Ride: 2003 ZX7R
If I had the machining equipment and skills, I'd do this for sure and it seems like a viable solution for someone to make and sell to the Kawi community. Would anyone be up for trying something like this?
http://www.badweatherbikers.com/buel...tml?1202407572
post #9 of 16 (permalink) Old 02-02-2013, 02:22 PM
You can buy a converter that screws into the speedo drive and interprets the signal right there. Then it's just a wire coming up to connect to an aftermarket gauge. What you posted won't work on your factory gauges at all.
post #10 of 16 (permalink) Old 02-02-2013, 02:24 PM
Masta Squidge's Avatar
I Ride: '09 Concours 14, '89 RC31 and Ѡ dat ass
Mine fell off repeatedly, so I went to the place I bought it from and commandeered a bottle of blue loctite. Been on for over a year without problem since.
The rear tire on my 14 is low on air.
So I was thinking of rebuilding the motor.
If that doesn't correct the problem, probably replace all the fairings
▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬
I ride a Honda.
Masta Squidge is offline
post #11 of 16 (permalink) Old 02-02-2013, 02:50 PM
I actually just had some superglue laying around the last time it came off for me. It still stuck on there in my spare parts bin in the garage. hahaha
post #12 of 16 (permalink) Old 02-02-2013, 02:59 PM Thread Starter
I Ride: 2003 ZX7R
The first thing I posted is from Dakota Digital, it's an adapter for mechanical to electronic or at least appears to be. Their descriptions are pretty vague IMO so it's hard to tell. I'm not trying to wire in my current analog gauges, just something like a zx14 or zx10 or something newer with a digital speedometer and analog tach or maybe something aftermarket but I figured I could find a decent gauge cluster locally at a decent price from someone parting out a wrecked bike or something. It's just a thought, if it seems like it'll get a bit too expensive then I won't go through with it. I just want something a little different and this cable breaking brought up the idea.(which I'm sure isn't the first time it's been brought up around here)
post #13 of 16 (permalink) Old 02-03-2013, 11:06 PM
nwlzch85's Avatar
I Ride: 99 ZX7R
lol. yeah common problem, they vibrate themselves loose. i used some plumber's tape and it solved the problem. just wrap the end with a layer or so, then screw in tightly. ;)
>For any rider: Keep that pretty side up...
>The seat of knowledge is in the mind; of wisdom, in the heart.
>Pain is inevitable; suffering is optional...
>The greatest mistake you can make in life is to be continually fearing you will make one.
>Breathe - inhale hope, exhale determination
2006 ZX636 - riding daily >> 1999 ninja zx7r - sold >> 1995 zx9r - parting out >> 1995 zx7r - wrecked >> 1994 zx7r - sold >> 1986 sabre v65 - sold
nwlzch85 is offline
post #14 of 16 (permalink) Old 02-04-2013, 07:10 AM Thread Starter
I Ride: 2003 ZX7R
I looked at it yesterday before I went for a ride and thought it was broken. Looked a little deeper and found the nut that screws onto the cluster so it went back on fine. I started riding yesterday and noticed that shifting was pretty uncomfortable as well and I had to point my foot at the ground to get under the shift lever. Got home and adjusted the shift arm(whatever it is) and all is fine. I didn't know it could be adjusted at all but its fine now thankfully.
post #15 of 16 (permalink) Old 02-04-2013, 05:17 PM
nwlzch85's Avatar
I Ride: 99 ZX7R
certainly glad to hear you got it all worked out. and yeah, adjusting the shift lever to your foot is a great thing! not all of us are 5'6 or 6'5... make it so its comfortable to be under, but then rmmbr to not make it so high that its a bear to shift down. ;)
nwlzch85 is offline
post #16 of 16 (permalink) Old 02-04-2013, 06:09 PM Thread Starter
I Ride: 2003 ZX7R
Yeah, I adjusted it, sat on the bike, adjusted, sat on the bike. Gonna try to take it out again by like wednesday to make sure it's where I want it though. Hopefully it doesn't rain on Wednesday so I can ride.
