I Ride: 98 zx-7r, 84 honda vf 750f
ok so from a troubleshooters stand point lets firsts break down the probable causes. the switch, fuse(s), relay(s),and wiring. and first check the cheapest fixes suck as fuse(s) and wiring. be sure to physically check the cable from the starter to the relay for damage because the cable is pretty hidden. if you have to take a ohmmeter to the fuse(s) to properly verify they are in good condition, i have had an old fuse crack and break without blowing before so it wasnt obvious. you can functionally test the relays by providing 12v to the terminals and verifying they are working properly. even check the brushes on the starter itself because if they are worn out it will act as if the bike has a dead battery.
Sir Airplane Greasin, Curve Carvin, Badass Mofo Monkey Whore of ZXF
98 ZX7R -
84 VF 750 F - Blown Head Gasket (in repair on backburner...)
if your not living on the edge your taking up too much space
