Intermittent dropping cylinders on k2 - ZX Forums
post #1 of 15 (permalink) Old 08-29-2019, 08:22 PM Thread Starter
Johnnyo556's Avatar
Recently my k has started to not fire on a couple cylinders at low rpm”s when it gets warm? Starts up fine and idles good for a few minutes and just dies. Hard restarting doesn’t want to run smooth below about 4000 rpm. Any help greatly appreciated. Thank you in advance.
Click image for larger version
Johnnyo556 is offline
post #2 of 15 (permalink) Old 08-31-2019, 05:15 AM
motocon's Avatar
I Ride: 99ZX7R (street) 98 ZX7R (track). 89 ZX10
I would start with the easy stuff.
Note and confirm which 2 cylinders are not firing when warm.
Those bikes have 2 coils that each fit 2 cylinders. I believe 1-4 and 2-3.
Then swap the coils and see if the same 2 cylinders drop off.
A simple plug wire can cause grief too.
Text the pick up coil.
The running smooth issue and hard starting sound to be fuel related.(if the ignition stuff all passes)
Could be needle valves are not sealing, pilot jets etc.
Take your time and write everything down as you go through the bike.
If you have not made any recent changes to the bike it is likely something simple.
Don’t lose faith.....
motocon is offline
post #3 of 15 (permalink) Old 08-31-2019, 10:41 PM
mte78's Avatar
That Hindle exhaust looks great. Good luck with finding the gremlins.
mte78 is online now
post #4 of 15 (permalink) Old 09-01-2019, 06:00 AM
ninjanut's Avatar
Also try simply trimming the wires and reinstalling the caps on the wires.
ninjanut is offline
post #5 of 15 (permalink) Old 09-01-2019, 11:56 AM Thread Starter
Johnnyo556's Avatar
Thanks guys!
If it is a coil what other model and years are compatible with the 91-92 k’s ?
post #6 of 15 (permalink) Old 09-01-2019, 12:59 PM
57x
7777
57x's Avatar
Originally Posted by Johnnyo556 View Post
Thanks guys!
91-03 ZX7/ZX7R
The parts list shows a difference by year, but I have swapped them across years several times.
Start with wires first. It is often the issue. Most coil failures I have seen on these are heat related. Great when cold and failure when hot, back working again when cold. Pull all the coil nuts, push the cap back with the washer and trim them at the line on them, around a quarter inch and reattach them. If this does not fix this then move to coils.
57x is online now
post #7 of 15 (permalink) Old 09-01-2019, 05:50 PM Thread Starter
Johnnyo556's Avatar
Ok thanks I will try that this week. I also did just put in a new battery but not a Yuasa... could that also be part of the problem ?
post #8 of 15 (permalink) Old 09-04-2019, 05:53 AM Thread Starter
Johnnyo556's Avatar
How do I test the pick up coil?
post #9 of 15 (permalink) Old 09-04-2019, 07:36 AM
Battery brand should not matter. Swap the coils and see if issue comes up again. Easiest way.
evan_calgary is offline
post #10 of 15 (permalink) Old 09-06-2019, 01:22 PM Thread Starter
Johnnyo556's Avatar
Coils test good so I’m digging deeper!
post #11 of 15 (permalink) Old 09-06-2019, 03:55 PM
motocon's Avatar
Sid u meter them or actually swap them and ride?
Sometimes coils test fine but when they get hot things start to fail.
Did you take Ninjamut’s advice and cut 1/4 inch off each plug wire and reattach? I did both my bikes years ago and it solved a similar issue.
motocon is offline
post #12 of 15 (permalink) Old 09-06-2019, 04:57 PM Thread Starter
Johnnyo556's Avatar
I just tested all the components with a meter and everything was in spec so I figured while I had it apart I’d clean the carbs again.
post #13 of 15 (permalink) Old 09-06-2019, 05:20 PM
motocon's Avatar
If you’re into carbs I would replace all the needle valves.
Careful not to bounce back and forth when fault finding and keep track of what you are doing and the results of each step.
You’ll get this👍
motocon is offline
post #14 of 15 (permalink) Old 09-06-2019, 08:44 PM Thread Starter
Johnnyo556's Avatar
Yes already ordered new needle valves today.
Just take a look at these pics... the number 1 cylinder intake valve chamber only on the left has a little browning going on (1st pic) and all the rest are spotless(2nd pic) mean anything?
ID:	10744   Click image for larger version
post #15 of 15 (permalink) Old 09-12-2019, 09:04 AM Thread Starter
Johnnyo556's Avatar
#2 carb had some crap clogging the slow pilot jet. Idles good now but haven’t taken it out to see if that cleared it all up.
