WTB: J/K Windscreen & Fuel Pump Relay - ZX Forums
post #1 of 8 (permalink) Old 05-22-2019, 02:46 PM Thread Starter
Hello!
I am after a fuel pump relay to fit a 7. I believe any model will work. Looking for something previously working/ tested as I have 3 of them here that do not work.
Also looking for a windscreen (stock preferred) for a J/k model. Looking for very good shape.
If anyone has some fork caps (just the caps) that fit a J/K and are in very good shape I may be interested too. Looking for no marring as the ones I have were scared up a bit by a PO.
evan_calgary is offline
post #2 of 8 (permalink) Old 05-23-2019, 06:57 AM
57x
7777
57x's Avatar
Are you sure it is the fuel pump relay? I have so seldom seen those fail. Does the bike start?
57x is offline
post #3 of 8 (permalink) Old 05-23-2019, 07:25 AM Thread Starter
Yes it is the relay. It has already been diagnosed. There is an easy test procedure to boot. You must have a good one to spare if they do not fail then correct?
post #4 of 8 (permalink) Old 05-23-2019, 05:40 PM
I Ride: 1990 ZX-7 H2, 1992 ZX-7R K2, 1992 ZX-7/9, 2002 Ducati 900ie Supersport, etc...
Originally Posted by evan_calgary View Post
Hello!
So Evan, you after the J (43mm) or the K (41mm) caps mate?
Necron9d9 is offline
post #5 of 8 (permalink) Old 05-24-2019, 06:56 AM Thread Starter
Ah, they are different sizes eh? In that case I suspect I am going to have a harder time finding them as I need the K caps...
Why did Kawasaki choose a more narrow tube for the K forks?
post #6 of 8 (permalink) Old 05-24-2019, 12:36 PM
Yes, definitely different, but actually easier to find than J caps... Well not really as I have a set that might have worked for you I could pull from a wreck set of J boingers.
The fully adjustable 41's on the K were done for less weight, but the good news for you here is that any L (or M) set of caps are also: 41's!
A set of L caps should be turning up on Ebay anytime. Maybe someone on the forum has a spare set now?
post #7 of 8 (permalink) Old 05-25-2019, 08:46 AM Thread Starter
Dude, super valuable info.! Thanks for the insight. That should help me out for sure. I will check bay. Guessing may have to buy a set of forks.
post #8 of 8 (permalink) Old 05-26-2019, 04:25 AM
My pleas. Also, you could actually just get a set of L forks that are cleaner than yours, take the K and L sets apart, and build withthe nicest tubes and caps in the set.
Someone can correct me if I'm wrong, but you could then use the rebound adjuster equipped lower legs from your K and all should be good. Presto- clean "K" forks.
Similar Threads
fuel system problem....fuel filter ???, fuel pump ???, fuel injectors ??? arbalet4ik ZX-6R Forum 5 11-09-2011 11:07 PM
to fuel pump or not to fuel pump Happydude123 Mechanical & Technical 8 03-21-2010 06:37 PM
Wanted: 95-97 ZX-6R Starter Relay & Fuel Pump ZX600F Motorcycles for sale 0 09-23-2009 09:36 PM
starter relay and fuel pump relay?? f7firecat Mechanical & Technical 3 09-22-2008 07:02 AM
WTB fuel pump & relay cwill ZX-11 Forum 0 07-11-2008 03:55 AM
