06 636, Weird Noise Coming From Gas Tank??? - ZX Forums
post #1 of 19 (permalink) Old 04-13-2010, 06:30 PM Thread Starter
greeneyess82's Avatar
I ve noticed when turning off the bike after a ride, there seems to be a whistling sound the seems to be coming from inside the gas tank.. when i open the gas cap, the sound goes away. but sometimes when i close the gas cap, it returns for a bit then goes away. its driving me crazy. what can this be??? thnaks fellas
06 Ninja 636
08 vulcan 900 custom
http://www.meancycles.com/ownersbeta...e&ownerID=3320
greeneyess82 is offline
post #2 of 19 (permalink) Old 04-13-2010, 07:02 PM
draggin636's Avatar
I Ride: zx-6r 636
sweet i'm not the only one that has that happening to..i thought i was going crazy for a while the one night after some drinks
draggin636 is offline
post #3 of 19 (permalink) Old 04-13-2010, 07:16 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
It's just your tank venting. Nothing to call Dr. Phil about.
Hammerhead is offline
post #4 of 19 (permalink) Old 04-13-2010, 07:20 PM
NickySixx3Sixx's Avatar
I Ride: 2006 636
Its the inscreased pressure in the tank.
One way you can make sure its safe is pull the tank and follow the black hose that runs to the bottom of the bike, make sure thats not pinched when the tank is on.
2006 636
NickySixx3Sixx is offline
post #5 of 19 (permalink) Old 04-13-2010, 07:32 PM
BigJonOU's Avatar
I Ride: 11 ZX10R
You bike gets hot by the sun... when this happens, the gasoline vapors expand creating an excessive amount of pressure in the tank. This pressure is vented and sounds like a whistling. Bam
SOLD FŁckenfast 2011 Kawi ZX10-R
Akra system minus the headers
BMC Race Filter
PC5 w/ custom map by Huckeby Brothers Racing
Shogun Sliders
Puig Smoked Double Bouble
CRG Roll-a-click Levers
DMP Smoked Integrated Tail Light
Nice & Sticky Power One's
GoPro Camera
SOLD Blacked Out '06 Ebony ZX-6R 636.
Helmets:
Arai Corsair-V Haslem
Arai Corsair-V Dani Pedrosa
Never ride faster than your guardian angel can fly.
BigJonOU is offline
post #6 of 19 (permalink) Old 04-13-2010, 07:47 PM
Shifty1's Avatar
I Ride: 2005 ZX6R
Yup, nothing to worry about.
-Poetry written in gasoline.
Shifty1 is offline
post #7 of 19 (permalink) Old 04-13-2010, 08:04 PM
their is a vent for the gas, sounds like yours is clogged.
oren102 is offline
post #8 of 19 (permalink) Old 04-14-2010, 11:30 AM
Wizzard's Avatar
I Ride: ZX9R
Exclamation Be Carefull!!
BE CAREFULL My tank was doing this last summer I thought the same as you guys but I was wrong it was the tank venting but the reason I could here it is because it was not venting right it was coming out around the cap.The vent in the cap was not working and not allowing the tank to vent thus pushing the air out around the cap,eventually backing up and pushing the gas past the fuel pump and flooding the engine through the carbs and down in to the oil.
I fixed this by taking the fuel cap apart and removing the parts that allow the vent to open and close (this is to keep gas from leaking out if the bike gets laid down) I even drilled the hole in the bottom of the cap a little bigger just in case.
Hope this helped it something to check on. I checked by removing the fuel cap and blowing into the hole on the bottom,just make sure you are holding the cap right side up.
ZX9R 2000
KZ 1000 1977
Wizzard is offline
post #9 of 19 (permalink) Old 05-22-2010, 08:30 AM
tilefish's Avatar
I could be demons or lost souls trying to get out
Consult a Holy person, you bike might need to be exorcised
"He who kicks a dog, kicks his own soul towards hell"
-Will Judy
tilefish is offline
post #10 of 19 (permalink) Old 05-22-2010, 08:40 AM
I Ride: 06 ZX636
Have a look under the fuel cap and you'll see some springs. Give things a push and it should become clear what's happening which is in line with some of the views above....
Twentytoo is offline
post #11 of 19 (permalink) Old 05-22-2010, 08:50 AM
clarkmanning's Avatar
I Ride: '08 ZX10r
Kawi whistle
clarkmanning is offline
post #12 of 19 (permalink) Old 05-25-2010, 01:35 PM
XanderZX6R's Avatar
I Ride: 2005 Ninja ZX-6R
love it...
if that vent hose from the cap to the spill pan is blocked you could get a vapor lock and it will cause your bike to stall out after riding for a while (my experience about 45mins in the heat). good tip to know and my advice is whenever you raise the tank, when you put it back down blow (don't inhale) into the free end of the vent hose to make sure you're getting good flow. Mine still whistles though but Jet planes and helos whistle when they're cut off too so I guess it's just that badass machines whistle
XanderZX6R is offline
post #13 of 19 (permalink) Old 05-27-2010, 08:56 AM
spcclinton's Avatar
I Ride: 07 ZX-6R
My girl called me two days ago while I was out of town to tell me that she heard my gas tank making a weird noise, put the phone to it for me to hear. I told her it was venting due to the heat and expansion etc.....she then said "so it's not going to blow up or anything is it?" LOL
Live Free or Die Trying
PC III, K&N Air Filter, Yoshimura RS-3 Muffler, MJS Performance Headers (ceramic coated), HealTech X-TRE, Kleen Air Mod, NGK Iridium Plugs, Amsoil, Supersprox Sprockets (15, 45), RK 520GKW Chain, HealTech SpeedoHealer, PP2CT, HEL SS Brake Lines, Pazzo Levers, Corbin CF Seat, DDM Tuning HIDs (6k), 9-LED City Light (white), SportBike Lites SS FE, DB Windscreen, Tire Hugger, "Ninja" Bar Ends, Frame Sliders, Fork Sliders, Rear Spools, CF Heel Guards, CF Exhaust Cover
spcclinton is offline
post #14 of 19 (permalink) Old 05-27-2010, 10:07 AM
Silverfox's Avatar
I Ride: ZX10 C2 2005
this is the difference between FI bikes and carb bikes the venting noise is the bike sucking in air-- this was never heard before on gravity feed bikes with fuel pumps not in the tanks to feed the carbs - the point is the fuel pump is in the tank now and when you tun it off the tank is still under vacuum from pumping fuel to the injectors hence the tank whistle, any help
Silverfox is offline
post #15 of 19 (permalink) Old 05-27-2010, 12:36 PM
I made a thread a few weeks ago..."singing gas tank", I know it's normal but mine seemed to do it often..pulled the tank vent line was squished flat from PO I guess. All is good now. No more noise at all.
SAKI
SAKIDUDE05 is offline
post #16 of 19 (permalink) Old 06-03-2010, 01:34 PM
speedemon636's Avatar
I Ride: 06 ZX6R 636
I just noticed the same thing on mine today, glad i found this thread.....it was driving me crazy
http://www.youtube.com/watch?v=dNw2M8liqQM
Mods:
-1 +2 520 chain
K&N Filter
PCIII
Flush Mount Blinkers
Fender Eliminator
ZX Racing Grips
Blacked Out Windscreen
Muzzys Slipon
speedemon636 is offline
post #17 of 19 (permalink) Old 06-03-2010, 02:40 PM
oliver's Avatar
isnt that when they peel the skin of your peter?
IF YOU'RE GOING TO BE STUPID, YOU BETTER BE TOUGH.
US ARMY AVIATION
" Sir Twisty Crashin, Dirt pile Squiddin Cali Whore of ZXF "
CALI WHORE REP
oliver is offline
post #18 of 19 (permalink) Old 06-03-2010, 03:28 PM
spcclinton's Avatar
I Ride: 07 ZX-6R
ouch!!
post #19 of 19 (permalink) Old 06-05-2010, 12:28 AM
Crazyninja's Avatar
I Ride: '08 ZX6R
one of my buddy's with an 07 z1000 kawasaki had his tank to expand and get out of shape on this bike. he attributed this to the failure of the check valve in the gas cap. his tank is messed up and bent from excessive vapor pressure. The fix is to take the latching mechanism apart and remove a round rubber piece where there is a little platic disk about the diameter of a pencil eraser out and then replace everything. no more whistle.
2011 ZX10-R (stock), 2008 zx6r (all the mods).
Crazyninja is offline
