Valve Diagnosis - ZX Forums
post #1 of 8 (permalink) Old 07-06-2019, 09:44 AM Thread Starter
I Ride: '96 Gpz1100, 11 Voyager, 07 ZX14
Garage
Valve Diagnosis
Noticed this on exhaust port #4, while stock pipes off. Feedback?
Other ports nice ash grey , like on right side of pic.
Click image for larger version
GpzRider is offline
post #2 of 8 (permalink) Old 07-06-2019, 02:53 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
My guess is the enrichener needle on that cylinder's carb is not seating fully and you're getting an extra shot of raw fuel running through on that side.
Hammerhead is offline
post #3 of 8 (permalink) Old 07-06-2019, 04:28 PM Thread Starter
Garage
Pic is on a 2007 ZX14. My profile a bit outta date.
GpzRider is offline
post #4 of 8 (permalink) Old 07-17-2019, 09:08 AM
Pull the plug and see what that's like. The port looks a little wet...that means a a valve guide seal, most likely, is giving up the ghost and letting some oil past.
2012 ZX14R SE
ZXual Speeding is offline
post #5 of 8 (permalink) Old 07-18-2019, 06:13 AM
quisp's Avatar
Possibly Oil sucked past gasket for Kleen air injection port .
quisp is offline
post #6 of 8 (permalink) Old 07-18-2019, 03:53 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
Then I would say you have a valve running very hot. Low compression would affect both and not much chance of one going cold. Compression and leakdown test may tell you something.
Valve clearance has 2 functions; the first, everyone knows, which is to assure the valve closes completely to facilitate compression.
The second is to cool the valve. The amount of clearance (duration from contact to contact of the cam lobe) determines the amount of time the valve spends on the seat. Too short a duration, no chance to transfer heat. Too much duration and heat
actually passes back into the valve seat and the valve head.
post #7 of 8 (permalink) Old 07-21-2019, 03:13 PM
Other than clearance, the number one cause of burnt exhaust valves is a sacked out valve spring. There is surprisingly little seat pressure on these bikes, like 28 pounds or so, so, ther isn't much margin for error if one starts to get soft.
post #8 of 8 (permalink) Old 07-23-2019, 05:53 AM Thread Starter
Garage
Thanks all
Plugs looked ok when I got the bike. Factory with larger work gap. Colour tan.
Will do a compression test.
Guess the only solution is surgery. Head removal, inspection, valve job.
GpzRider is offline
